View Full Version : Jamming Bizhub 367 , jam 20-22
pinspin
02-01-2021, 05:53 PM
Hello! The copier jams from the second cassette, code 20-22. We changed 3 rollers and 2 clutches of the second cassette. It did not help. We would be grateful for any advice. Thanks.
tsbservice
02-01-2021, 08:09 PM
Jam 20-22 is misfeed at vertical transport section (tray 4), are you sure about second cassette?
pinspin
02-01-2021, 08:14 PM
oooh ,you are right friend , 20-02 my mistake .thanks
tsbservice
02-01-2021, 08:20 PM
You meant 2 oneways of pickup and feed roller shafts? If so I would try also changing torque limiter(A0ED563900) of separation roller shaft.
pinspin
02-01-2021, 08:44 PM
Yes ,we replaced 2 oneways and A7AH - M205 , A7AH-M204 .We will change torque limiter .Thanks .
tsbservice
02-01-2021, 08:51 PM
Yes ,we replaced 2 oneways and A7AH- M205 , A7AH-M204 .We will change torque limiter .Thanks .
Let us know. Good luck.
pinspin
02-03-2021, 03:57 PM
Done .We replaced torque limiter and used Paper feed Guide ( with white rollers ) . Thanks for help .
tsbservice
02-03-2021, 07:11 PM
Sure not a problem. Thanks for giving always feedback not many do as you did :)
