View Full Version : Reboot Olivetti d-Color MF282plus
Hi, I have a client with an Olivetti D-color 282Plus.
The printer keeps restarting every 2-3 seconds. Looks like a bizhub C284e to me. In all likelihood, the SSD no longer works. I tried to detach DF and HDD. Do you think I can insert a new Bizhub C284e SSD?
GIUBOSS
02-04-2021, 09:15 AM
Try updating the firmware first
barber782
02-04-2021, 09:57 AM
Try the Sata controller fw v4 first
Sent from my VTR-L09 using Tapatalk
barber782
02-04-2021, 09:58 AM
And.. You can try usi g the diagnostics screen to see if there's an issue
occus
02-04-2021, 11:01 AM
Yes, change the SSD. I replaced a few last year, even with the controller firmware fix installed...
Sometimes you need a total clear and Moviedata after replacing it, if you get a SSD error.
copier tech
02-04-2021, 11:52 AM
If the machine is on a continual boot loop the SSD has failed & the only option is to replace it.
You won't get the firmware to update because the machine is continually rebooting.
Yes you can use a Konica Minolta SSD. (must be new)
occus
02-04-2021, 02:36 PM
No, you can use a old one!
Replace and put in usbstick with newest firmware on first boot. Most time it works, sometimes you need a clear all data.
copier tech
02-04-2021, 02:41 PM
If you use an old one to risk having a counter mismatch error.
I have ordered a new SSDB.
I will be using the firmware of a bizhub C284e. I believe that "plus" corresponds to the "e" series.
I will let you know
occus
02-05-2021, 11:48 AM
Yes, plus means (e)nhanced.
Try the KM fimware, but it happened once that it didn't work, it depends on the firmware version. Then software switch 10 from 04(generic Brand) to 01(KM)
Hi, I proceeded like this:
- Replaced SSD but keeps restarting.
- Removed options but keeps restarting.
- RAM removed: MFP stops restarting but nothing comes out on the display. Startup noise only.
- RAM replaced unsuccessfully.
At this point I am thinking of a broken MFPB. Some idea?
emujo2
02-08-2021, 05:33 PM
if you think it's a 284e how many "fins" pop up before it re boots..and have you tried doing a trouble reset to get to the point where you can enter service mode to check what the error is?
The printer fails to turn on, so no errors displayed.
At this point I think PSU or motherboard defective.
emujo2
02-08-2021, 08:18 PM
Your OP says re-booting..in most cases the re boot occurs after the LCD shows something..Number of fins coming up can help in troubleshooting..So you are saying you power it on and it cycles on/off at this point? E
tsbservice
02-08-2021, 09:27 PM
2-3 seconds are not enough to see anything meaningful Ed.
occus
02-09-2021, 06:33 AM
Was it possible to load a firmware after replacement? Try reseat SSD.
CP-1015
02-09-2021, 06:56 AM
I will let you know
Yes, it's the C284e.
Hi, the printer can only stay on for 2 seconds, so:
- Unable to log in in service mode.
- Reset tool does not have time to start.
- Failed to update firmware.
Thank you!
occus
02-09-2021, 10:20 AM
48215
48214
Bix, do you have a new SSD with green Dot? (with 6.05 already installed?)
Have a look in the troubleshooting guide.
If you can't install the firmware i think it is not possible to boot a new ssd up.
Once i forgot the firmware after replacing the ssd the device always had a bootloop.
And check your firmware in Knova. Are the generic brands, (olivetti D-Color, Develop ineo) listed in the compatibility list?
Hello occus, thank you for your reply.
in germany we are having logistical problems due to bad weather and the parts are arriving late. I have ordered a new SSD which is yet to arrive
For now I have taken a used SSD to make it stop rebooting. But I have seen that the solution is not effective. The printer keeps restarting anyway.
Firmware is also unknown. I wanted to try a Konica Minolta firmware because there seems to be no Olivetti firmware on Knova.
copier tech
02-09-2021, 10:40 AM
You need to fit a NEW SSD.
Hi, good news.
The SSD used was not working but I received the new SSD (identical for Konica Minolta 4e series).
Now it works again!
Thank you all for the support.
Special thanks also to @occus!
By the way (it has nothing to do with the problem). For those interested: Konica Minolta toners and drums cannot be inserted on this olivetti 282+. it is necessary to make some modifications to the plastics.
copier tech
02-10-2021, 08:55 PM
Hi, good news.
Now it works again!
I told you to fit a NEW SSD!
Yes, I also said a few posts ago.
But the weather was bad in Germany, transport slowed down.So in the meantime I had inserted an SSD used to understand if it stopped restarting. But this technique doesn't work.
copier tech
02-10-2021, 09:28 PM
No, as I said you can't fit a used SSD for this issue.
I was hoping it would stop rebooting and return an error with used SSD.
I keep learning from mistakes. Thank you.
copier tech
02-10-2021, 10:37 PM
Always worth trying used parts but to be honest in my experience you have a much higher success rate fitting brand new parts & often fitting used boards you create more issues.
