View Full Version : bizhub c300i jam tray 1
Cantechman
02-04-2021, 05:49 PM
I have a new C300i install with intermittent jam codes 1102 and 1105 from tray 1. Everything related passed the load check. I replaced the whole feed section and it seemed ok temporarily. Any ideas what to try?
copier tech
02-04-2021, 07:26 PM
I assume you have done the basics, like trying a new pack of paper, updating the firmware etc.
If its a brand new machine pass it back to KM under warranty.
Where the paper stop?
Cidermatt
02-06-2021, 02:08 PM
replace, the reg sensor and put another turn on reg actuator!!
Cantechman
02-08-2021, 06:40 PM
Yes did both.
Cantechman
02-08-2021, 06:43 PM
I have another complete registration unit to try. It happens intermittently so it's a little difficult to diagnose. If that doesn't work i will try the paper feed roller fast clutch and then finally the base board.
Cantechman
02-08-2021, 06:45 PM
[QUOTE=Bix;1680974]Where the paper stop?[/
Sometimes it doesn't leave the tray, other times it does so no specific place. one or 2 prints seem to be fine it's multiple prints where the issue starts.
tsbservice
02-08-2021, 06:50 PM
I guess then that will rull out entire registration section. After you replaced whole feed unit does it work?
allan
02-08-2021, 06:57 PM
So you say it works just fine with another feeder unit?
Cantechman
02-08-2021, 07:55 PM
[QUOTE=Cantechman;1683731]
it seemed to initially but the customer called back a week later and said it's happening again.
Cantechman
02-08-2021, 07:57 PM
It seemed as though it did for a week or so, must have been a coincedence.
EarthKmTech
02-08-2021, 10:41 PM
make sure its not the cassette itself - i have seen straight out of the box from new damage to the very top edge of the mylar at the rhs of the cassette. Not even visible to the eye but can be felt by the finger nail, and sufficient enough to trap the top sheet feeding out the tray.
I've also seen mylars installed crookedly by 1-2mm on the feed unit guides straight out of the factory causing jams too. (tray 2 jams)
Cantechman
02-11-2021, 02:33 AM
The problem was the fast clutch (cl10). It's behind the base board. Once replaced and tested it worked fine.
brent
03-23-2021, 09:54 PM
cantechman I see the clutch on the diagram and going to order it.. super fun to install? lol since I don't have another machine here in the office to try with
until I get the part.. thank you very much for the link you guys are awesome
brent
Cantechman
03-24-2021, 12:28 PM
brent
It wasn't that bad, the hardest part is just opening up the baseboard box, I'd say start to finish it took 45 min.
I wanna ask, what's the function of this fast clutch?
allan
03-24-2021, 09:24 PM
I think its to clutch fast.
Cantechman
03-25-2021, 04:30 PM
I never really read what it's function is other then helping transport the paper but's only related to tray one and the bypass I do believe.
brent
04-07-2021, 07:47 PM
I just received my clutches from km there probaly isnt a procedure in the book I assume? I wish I had another machine in the office to try on first so I don't look like a dork in the customer office.. lol I need to get it on the schedule and get it replaced.. you need to remove the base board is that right?
thanks brent
brent
04-07-2021, 09:07 PM
looks not too bad. I hope to get to the customers office next week early.. I will advise.. it is in the manual as well as far as the clutch 10 I didnt see
it before. but now I do. thanks all
brent
Cantechman
04-08-2021, 04:58 PM
There is a procedure for that particular clutch in the manual. you have to open the "box" not remove the board itself.
thanks brent
avecosat
05-18-2021, 12:37 PM
How about the solution? I have the same problem (11-02) in a C250i is the clutch the solution
from my understanding...yes
blackcat4866
05-18-2021, 03:16 PM
If you read the other posts in this thread you might conclude that CL10 did fix the issue. =^..^=
Phil B.
05-18-2021, 03:36 PM
yup reading required
Cantechman
05-18-2021, 04:56 PM
Hasn't been issue since it was replaced.
avecosat
05-20-2021, 11:48 AM
KM solution for Jam 11-02 , I have tried it and for the moment is work.
49196491974919849195
tsbservice
05-20-2021, 02:31 PM
Great, more precise engineering from Konica Minolta :cool:
tmmdmmm
05-21-2021, 01:29 AM
Not seeing anyone else mention it
We've had all our i series come with the Fusing speed maxed on delivery. Dropping it from +7 to 0 stopped intermittent jams from T1 and T2
tsbservice
05-21-2021, 06:57 AM
Good advice although in case of 11-02 jam paper should stop before fuser so fusing speed doesn't matter.
