View Full Version : Miscellaneous Printing specific pages on different paper AccurioPress 6120
anteas
02-06-2021, 06:53 AM
Hello
How do to Printing specific pages on different paper with AccurioPress?
Page 1 print on blue paper,
page 2 print on red paper,
page 3 print on yellow paper,
page 4 print on green paper,
Then the cycle repeats,
Page 5 print on blue paper,
page 6 print on red paper,
page 7 print on yellow paper,
page 8 print on green paper,
then repeats again until the end of 444 pages
rrrohan
02-07-2021, 01:33 PM
You could just load a tray with paper colours in that order as a low tech option
Sent from my Pixel 4 XL using Tapatalk
tsbservice
02-07-2021, 02:09 PM
unconventional without a doubt :cool:
raplma
02-08-2021, 12:02 PM
Not having your exact press, nor knowing which version of CWS you have I cannot be sure this will work, but if I had a job come in like this, this is what I would try at first.
Load 4 trays on the machine each with a different colour - noting what colour is in each (obviously)
In Short:
Use CWS Media tab to asign the correct tray to each of the first 4 pages.
Then in the VDP tab set the 'Define record length' to 4 pages.
In detail:
Open CWS
Select Media tab
Click on [New Page Range]
Set "Define Media for Pages" to 1 (as in page 1)
Set "Input Tray" to whatever tray has the blue paper e.g. "Tray 1"
Leave all other options as "Document Setting" unless you had different types of media in terms of 'weight' and 'type'
Click [Add Definition] - Don't click [Close]
Repeat for page 2,3,4 changing the page range and input tray fields before clicking [Add Definition]
Once you've defined the trays for the first 4 pages click [Close]
You should have four lines in the "Mixed Media" window
To get the machine to repeat this order
Select VDP tab
Under the "Define Record Length" section set the Pages per record to 4.
I have used this on our setup especially for NCR and in effect the job collates on press.
Watch the image though, I found that on one job where it was critical (tabular artwork) that each sheet aligned almost perfectly, that when I had to use the bottom trays as well as the trays in the Paper Feed unit that the image was 2mm off, simply due to how the paper was aligned in the different tray types.
I'll be interested if this works on your setup
Good luck
Mark
I should say that this assumes that the artwork is a single .pdf file of 444 pages.
