View Full Version : BIZHUB 20
blinxwap
02-11-2021, 09:37 PM
I have an issue on a bizhub 20 constantly display jam inside single sided copies or prints page prints out than jam inside is displayed , have reset the printer fitted mew drum and toner as die old toner was dumping toner on the drum unit thought it might block a sensor or something jams from both trays after the page prints out any suggestions
Sent from my SM-A505F using Tapatalk
Phil B.
02-11-2021, 09:52 PM
would help to know the jam code...
leaking toner? if you stick a screwdriver on it does some of it stick to the blade
page counts?
blinxwap
02-11-2021, 09:54 PM
page counts?I dont know much about the b20 so i dont know how to checl the jam codes
Phil B.
02-11-2021, 09:56 PM
don't you have the user guide or service manual?
blinxwap
02-11-2021, 09:59 PM
don't you have the user guide or service manual?I will check tomorrow i will give more details then
allan
02-11-2021, 10:10 PM
You can troubleshoot this machine using a Brother 8880DN service manual.
blinxwap
02-12-2021, 08:21 PM
page counts?Error code 88 paper jam inside
Phil B.
02-12-2021, 08:25 PM
Sent from my SM-A505F using TapatalkNow answer my other questions.
blinxwap
02-13-2021, 02:04 PM
Sent from my SM-G960U using TapatalkPage count -270556 see attached pdf last toner delivery the mc is at the workshop will check if the toner sticks on the blade on or Tuesday ill keep you posted48289
Remove the drum assembly and check the paper sensor flags near registration roller. Should be one before and after the roller. Your error 88 points to the flag just after the reg roller. Broken or displaced? Piece of paper in the sensor?
