Arkangel1028
02-11-2021, 11:02 PM
I could use some help.
Our IT Network Admins require that a CSR is signed by them and installed on the MFD to be secured.
Turned off SSL
I have a Konica Minolta 368e, and have went into the Security/PKI, filled in all the necessary information and requested a CSR. The CSR was sent to be signed and received.
I've deleted the cert that came with the unit.
Opened the received cert in text format, chose import cert and pasted the text.
Turned on SSL for Admin and user using TLS1.1 and 1.2 with AES256 encryption.
The unit was then cold booted.
Every browser that I access the unit still shows Bad Certificate.
I would like to access the unit with HTTPS, however what did I miss? Is there instruction for properly installing signed certificates on a Konica Minolta 368e? My cert shows Root and Intermediate.
Any help is welcomed.
Thanks,
Turned off SSL
Thanks,
