View Full Version : Printing on the tabs of tab paper/index paper
rrrohan
02-15-2021, 10:12 AM
could of sworn it was possible to print on the tabs of the tab paper/index paper but cant seem to get it to work.
is it possible on the tab and if so can someone assist or point me to the part of user manual i missed that helps with this.
TIA
B0265
02-15-2021, 10:49 AM
Print (konicaminolta.eu) (https://manuals.konicaminolta.eu/bizhub-C658-C558-C458-C368-C308-C258/EN/bizhub-c658-c558-c458-c368-c308-c258/contents/id01-_102789583.html)
Look for the "Per page setting".
blackcat4866
02-15-2021, 11:49 PM
You don't specify what machine you're referring to. I had a school customer with a bizhub PRESS 1052 that put in a service call every month when the monthly financials were printed. She claimed she could not remember the instructions (every time, even when they're still posted on the wall).
Go to Machine > Tray Settings > select the desired paper tray > paper size Change Set (upper section) > select Tabs > OK > Change Set (middle section) > Image Shift > left shift (set to +100) > OK.
There's more about selecting the correct pages to pull the tabs. I'll have to look harder for that part. =^..^=
Here's the whole document:
To print tabs on bizhub PRESS 1052:
1) Re-order tabs in tray #4, so that tabs sequence from furthest back at the top of the stack to furthest front at the bottom of the stack.
Machine tab > Tray Setting > Tray #4 > "Paper Size" Change Set > 8.5 x 11 Tabs > 4 Tabs > OK > Image Shift > Change Set > Both Sides Adj. > Image Shift Right/Left: +100 > OK.
2) Insert Cover Paper in tray #5.
Machine tab > Tray Setting > Tray #5 > "Weight" Change Set > Weight > 136-162 gsm > OK.
3) Insert Plain Paper in tray #3.
4) Application > Insert Sheet:
Front Cover: Change Set > with cover/print > tray #5 > OK.
Back Cover: Change Set > with cover/blank > tray #5 > OK.
Insert Sheet: Change Set > tray #4 > Insert Page Setting > 6,21,112,122 > Fix > OK x3 > display jumps to Set002 (it's OK, look back to Set001 and check that all your settings are still there).
If there are too many pages to staple you'll have to use your heavy duty stapler.
The machine dis-allows tab paper combined with punch. If you need it punched you'll need to drill them.
I tried to save the job in Mode Memory but the machine does not store some of the key features.
rrrohan
02-15-2021, 11:56 PM
Not on production just a C754e.
I'm guessing I could just tell it it's custom size and specify the width including the tab?
Then play around with alignments of text in a word document
Sent from my Pixel 4 XL using Tapatalk
