View Full Version : biz 361 error c2801
Gab
02-15-2021, 03:16 PM
I know this error is about TCR sensor . Can it be something else?
Noted that at the beginning error 2558 i replaced the empty toner bottle and now i have this error.
copiray
02-15-2021, 06:23 PM
can you check the toner level in service mode?
Toxic
02-15-2021, 07:12 PM
How many prints developer and drum have?
Toner not OEM?
PS:why are you so red? :)
blazebusiness
02-16-2021, 12:54 PM
First thing to try after running the bottle completely dry like that and getting a code - is to go to service mode under image process adjust and select auto toner supply and hit the start copy button. When the auto add toner is finished the copy button will turn blue again. Turn copier off and on. If you are lucky the dv unit is just starved for toner and once you run that auto toner supply it will come right back with no error code.
If that doesn't work, time for developer or maybe a new tdc sensor.
