View Full Version : Bizhuib C258, missing network.
Savian
02-17-2021, 05:17 PM
Hi.
My BZ C258 just missed network configuration. Option Network Config does not appear in the Administrator tab or in the service menu. What can I do?
copier tech
02-17-2021, 05:48 PM
Hi.
Shut the machine down & unplug the LAN cable then power back on.
Sometimes the network setting page takes a while to appear.
Savian
02-17-2021, 06:05 PM
Nothing.
I was performing a Clear Network Data in service Mode when a energy blackout happend.
copier tech
02-17-2021, 06:11 PM
Nothing.
That was unlucky timing.
Update the firmware & try all ‘all clear’ in CE mode.
tsbservice
02-17-2021, 06:12 PM
Nothing.
You should start with this. Why not mentioned such a critical information?
Savian
02-17-2021, 06:27 PM
Update the firmware & try all all clear in CE mode.
That was what I feared. IŽll try to get a firmware.
Thanks you anyway.
Savian
02-17-2021, 06:29 PM
Sorry! IŽll be more especific next time.
tsbservice
02-17-2021, 06:55 PM
If you have difficulty to update FW try firstly doing Initialize All. Depends on what data is corrupt may help.
Savian
02-17-2021, 07:21 PM
Do you mean Clear all data?
tsbservice
02-17-2021, 07:25 PM
Yes.
Synthohol
02-17-2021, 07:55 PM
You will need movie data and re-enable the hdd following the all clear.
I can help with that if you need.
tsbservice
02-17-2021, 08:02 PM
Synt is always coming to help and more. My bad didn't mentioned this.
Savian
02-17-2021, 08:08 PM
Sure, any help will be welcome.
Savian
02-17-2021, 08:29 PM
Relax, I am sure you would do it next.
Synthohol
02-17-2021, 10:21 PM
check your PMs.
please consider becoming a contributor.
https://www.copytechnet.com/forums/vbdonate.php?do=donate
thanks.
Note that if there is the warning message "Prepare box/scan ...", the network setting will not be visible. You have to wait.
If there has been a blackout, something may have been compromised. A clear all data + hdd format could help a lot in your resolution
Keep us updated.
Savian
02-18-2021, 07:57 PM
It worked!
Clear all data + format hd + MOVIE files.
By the way, all image quality settings I had made, remain.
I would like to thank everyone who willingly guided me in solving this problem. Thank you very much and keep that spirit.
God bless you all.
tsbservice
02-18-2021, 08:29 PM
It worked!
God bless you all.
Keep safe Savian, it's always been a pleasure to help someone with goodwill.
