View Full Version : Bizhub C280 Firmware
wondernomore3
02-18-2021, 12:40 AM
Hi,
In need of the latest firmware for the C280. Any help would be hugely appreciated.
Cheers!
rrrohan
02-18-2021, 12:45 AM
Hi,
Cheers!
https://1drv.ms/u/s!Ah_79nptMOdwgYcGfPdBu50HTXFapQ?e=V5bhWB
(https://1drv.ms/u/s!Ah_79nptMOdwgYcGfPdBu50HTXFapQ?e=V5bhWB)GDR-D1
mgakono
02-18-2021, 04:36 AM
Hi
Can I apply the c280 firmware to two machines bizhub c360.and c220
Wanted to clear "no animation data " error
Successfully downloaded to a usb 32 formatted usb drive.
I can access the sp mode
Thanks for advice, before I brick anything!
rrrohan
02-18-2021, 05:22 AM
yeah it works on all 3
If your trying to get rid of the animation data error you will need the "movie data"
mgakono
02-18-2021, 11:29 AM
Oh thanks
so i can get to select "movie data" specifically from the firmware?
this would be excellent!
oluwatope333
09-22-2021, 12:02 AM
kindly help out with this link again, i'll need the firmware too pls
oluwatope33@gmail.com
oluwatope333
09-22-2021, 04:06 PM
Hi rrrohan, please consider me too, i'm in dire need of this firmware at the moment, thanks for the consideration
oluwatope33@gmail.com, thanks
Zesti
09-24-2021, 10:08 AM
check email...
oluwatope333
09-24-2021, 10:26 AM
check email...
thanks alot
sergiompnunes
11-02-2021, 05:47 PM
hello guys, will it be possible for someone to send me a link with the latest firmware for the bizbub C280
I have a machine with outdated firmware.
I need smb support and be able to scan to email office365
Thank you very much
email: sergiompnunes@gmail.com
Synthohol
11-02-2021, 08:01 PM
Machine too old. There is no firmware to enable current security protocols by Gmail or micro$oft.
Your machine is obsolete.
Perfect upgrade scenario as nothing can be done about it.
No longer supported by konica either.
Easiest workaround is to scan to a USB stick and email them from your computer.
That machine was officially discontinued and obsolete on 12/2019
sergiompnunes
11-02-2021, 08:17 PM
and when to SMB, is it possible to scan to folder?
is the last firmware available for this model, allows you to scan to folder... it's just like for smb1.0 I can scan successfully.
I would really like to try to update the firmware to the latest one available for this device
thanks
Synthohol
11-02-2021, 08:19 PM
You won't be able to scan to windows 8 or 10. Xp or maybe windows 7 only for smb v1
Really best to scan to USB stick or buy a new machine with current capabilities.
sergiompnunes
11-02-2021, 08:24 PM
i can and i have how to configure the scans for smb1.0 cifs 1.0
will it be possible to send me the latest firmware available for this machine
Phil B.
11-02-2021, 08:30 PM
will it be possible to send me the latest firmware available for this machineLoading SMB v1 is NOT recommended.. that is why MS is disabled it.
Ransomware can infect the computers attached to the copier.
copier tech
11-02-2021, 08:56 PM
Happy to help with the latest C280 firmware.
Please contact us at the links below.
You can still use an old Win 7 PC to SMB scan.
sergiompnunes
11-02-2021, 09:00 PM
This machine support smb2.0?
Smb 2.0 are Supported by Microsoft in windows 10....
This maquina have firmware Support smb2.0?
Thanks.
copier tech
11-02-2021, 09:49 PM
Thanks.
No SMB v 2.0 is not supported on the old C280.
Win 10 does support SMB v1.0 however you may need to enable it but others have said this presents a security risk.
50663
Synthohol
11-02-2021, 09:58 PM
c280 isn't even on the list
Konica Minolta fully supports scan-to-email using Microsoft® Office 365™ for the current workgroup models listed below.
Microsoft® Office 365™ uses SHA-2 for its mandatory hashing cryptography algorithm. In 2002, SHA-2 became the new
recommended hashing standard. SHA-2 is often called the SHA-2 family of hashes because it contains many different-size
hashes, including 224-, 256-, 384-, and 512-bit digests. Currently the most popular one is 256 bits.
As of January 1, 2016, Microsoft no longer allows certificate authorities in the Microsoft Root Certificate Program to issue
certificates for SSL, or code signing that uses the SHA-1 hashing algorithm. SHA-2 is now the preferred method.
The following are the incoming and outgoing IMAP server settings for Office 365.
Server Name
outlook.office365.com
smtp.office365.com
Port Number
993
587
Encryption Method
SSL
TLS
MODELS SUPPORTING OFFICE365
Monochrome Models
224e/284e/364e
454e/554e
G20-C4
654/754
GB0-A9
Latest Version-Up Firmware for MIF
654e/754e
G20-60
227/287
G00-84
4050/4750
A6F730G0516-W99
Page 2 of 4 Bulletin #: 10310
Color Models
C224/C284/C364
C454/C554/C654/C754
GB0-A9
C224e/C284e/C364e
C454e/C554e
G20-42
C654e/C754e
G20-80
C227/C287
G00-84
C258/C308/C368
G00-84
C3350/C3850
A3GN30G0516-W99
All devices must have TLS v1.2 enabled.
its just too old.
time to upgrade!!
sergiompnunes
11-02-2021, 11:58 PM
firmware installed :
can you check if the firmware I have installed is too old??
ROM Version
MFP Controller BOOT Program
A0ED0Y0-1E00-G00-00(00)
MFP Controller SubSet
A0ED0Y0-1F00-G00-15(00)
MFP Controller
A0ED0Y0-0100-G00-D1(00)
Operation Panel Message Data
A0ED0Y0-8100-G00-D1-500
Fax Board Controller1
Fax Board Controller2
Scanner
A0ED0Y0-0023-G00-85
Printer
A0ED0Y0-0050-G10-07
ADF
A0HU0Y0-0024-G00-01
Finisher
Panel CPU
A0P00Y0-8900-G00-00
DSC1
DSC2
LCT
Loadable Device Driver
SD
Voice Data
Movie Data
A0ED0Y0-A000-G00-01
Dictionary Data
OCR Library
MFP Controller System
A0ED0Y0-1000-G00-D1(00)
MFP Controller Print Controller
A0ED0Y0-3000-G00-7H
MFP Controller Print Controller Font
A0ED0Y0-3F00-G00-38
MFP Controller Print Controller Demo Page
A0ED0Y0-3E00-G00-01
MFP Controller MIO
A0ED0Y0-5000-G00-26(00)
MFP Controller PSWC
A0ED0Y0-5100-G00-10(00)
MFP Controller MIB IF
A0ED0Y0-5200-G00-10
MFP Controller IPP IF
A0ED0Y0-5300-G00-10
MFP Controller Outside Controller IF
MFP Controller TCP/Socket
A0ED0Y0-6300-G00-21(00)
MFP Controller OPEN API
A0ED0Y0-7000-G00-13(00)
MFP Controller Operation Panel
A0ED0Y0-8000-G00-D1(00)
MFP Controller CSRC Control Body
A0ED0Y0-8300-G00-01(00)
MFP Controller PIC
A0ED0Y0-8200-G00-A4
Synthohol
11-03-2021, 03:32 AM
that firmware is only 1 version behind, d2 is newer but will have no impact on SMB scanning.
you might also consider scanning to FTP and just map the folder to the workstation as if it were a network drive.
now you have 2 solutions ;)
your FW is from 12/2011 the newer is only 3 months newer.
if it aint broke, dont fix it.
try FTP scanning instead. works across the board unless your network blocks port 21?
herbert
11-03-2021, 12:16 PM
Oh thanks
Movie data comes differently
Dland
11-04-2021, 12:31 AM
Google Drive: Sign-in (https://drive.google.com/file/d/1RXTC0zcCMk6fs3y3dkoX7FnNvqEBAF7z/view?usp=sharing)
the link for movie data..
if need the newest firmware letme know!
please be patient for me to give you access to the file thank you
copier tech
11-06-2021, 09:51 PM
paingminkhant
01-22-2022, 04:14 AM
Hello sir, I have a trouble firmware error of my Konica bizhub c280/360. Can you help me please? paingminkhant955@gmail.com is my mail
Phil B.
01-22-2022, 05:15 PM
Hello sir, I really need your help for my konica c280/360 movie data error. May be possible can you help me please. Thank u. paingminkhant955@gmail.com is my mail.Damn 3 times in a row you beg for firmware but offer nothing in return.
Firmware is not meant for end-users to have.
And posting in several firmware threads only tends to piss people off.
CONTRIBUTE to CTN and your request will get filled quicker.
What error are you having? Firmware doesn't fix all problems.
rkessani
07-26-2022, 02:14 PM
Hi Guys, Please do help me out with the firmware also.
rkessani@gmail.com
Much Appreciated
rkessani
07-26-2022, 02:16 PM
Hi sorry but the link says expired, any chance i could get the link? thank you very much
techsxge
07-28-2022, 10:23 AM
For everyone requesting firmware here, there are a couple of easy ways to get firmware:
1. Buy it from a vendor like @copier tech
2. Become a Contributor to the Site
3. Have a good reputation on this Site by contributing your knowledge to others.
If you do any of these things, you will most likely recieve the requested firmware within 12-24h on here
Or atleast have a much higher chance of getting the firmware
copier tech
07-28-2022, 01:43 PM
Thanks for the reference & as always we're happy to help.
Printer & Copier Firmware - www.printerfirmware.co.uk (http://www.PrinterFirmware.co.uk)
Can someone send me the link also please
Joseph.williams@outlook.com
copier tech
08-16-2022, 09:04 PM
Happy to help.
We can supply most major manufacturers printer & photocopier firmware. Click Here To Download - Ricoh, Konica Minolta, Kyocera, Lexmark or Canon Firmware (http://www.CopierFirmware.co.uk)
rjjr148
10-03-2023, 12:12 PM
check email...
C280 special firmware for error clear 5501
Mail id - rjjr148@gmail.com
Thanks in advance
