View Full Version : Bizhub C280 - Disable warning message
wondernomore3
02-18-2021, 09:24 AM
Is there any way to disable the 'replace drum unit (k)' warning message?
The printer is still printing perfectly, so was curious if the message could be disabled in system settings?
Thanks in advance!
barber782
02-18-2021, 09:34 AM
http://www.copytechnet.com/forums/konica-minolta/56737-konica-bizhub-c220-c2-firmware-setting-post332363.html&ved=2ahUKEwiY7rq2kPPuAhWzp3EKHQdrA9YQFjADegQICBAD&usg=AOvVaw3bnFm4zL8YfhcrwtUdhSQx
You will find what you're looking for there
Sent from my VTR-L09 using Tapatalk
tsbservice
02-18-2021, 07:42 PM
Page not found
barber782
02-18-2021, 09:50 PM
How to apply end of life settings
1) Upgrade the FW to Version G00-C2 .
2) Make unit change setting.
Service Mode > System 2 > Unit Change > Set Service for Imaging Unit.
3) Select No Stop for each consumable.
For Imaging Unit\Drum Unit\Developing Unit.
Service Mode > Enhanced Security Mode > IU Life stop setting > set to “no stop”
For Transfer Belt and Fusing Unit
Service Mode > System 2 > Software Switch Setting.
Change Switch No: 55
Bit 2 _ ON (Transfer Belt Unit ‘no stop’)
Bit 3 _ ON (Fusing Unit ‘no stop’)
HEX should read ‘0C’ when both switches are set.
4) Eliminate Life Message Display.
Change Switch No: 51
Bits 4,5,6,7 _ ON
HEX should read ‘F0’ when all these switches are set.
