John-r
02-18-2021, 06:42 PM
Hi, I have a konica minolta accurioprint c759, I have a problem with the black color being a little washed out on unncoted paper from 120grs and up. Is this normal on this printer or are they possible with some sort of adjustment? The printer has only 20k print and has efi fiery, has also had the fuser temperature set up to max which helped a bit.
Image is not much washed out but the printer is used for greetingcards and works ok as long as they do not become dark images.
The colors are adjusted in fiery and are fine with the exception of dark colors but especially black
