View Full Version : Konica Minolta Bizhub 283 installing used fax board need information on install
Newguy
02-18-2021, 08:41 PM
Hello Looking for information on installing a used fax board into a Konica Minolta Bizhub 283. I can no locate a manual or information on this. If some one has a manul on installing this would like a copy if possible. I have found where it mounts but unsure if I have the right location on circuit board to install cable and usb cable. May have questions about setting this up to receive and send faxes watched some other videos on Konica Minolta Bizhub printers some are close in design but not the same.
Thanks ED
Synthohol
02-18-2021, 09:19 PM
well the physical part is like this....
making it work in service mode is after.
thats another procedure.
Newguy
02-19-2021, 04:21 PM
Thanks for all the help the pdf's I received helped alot was able to install and get the fax up and running.
Here is name of another install manual that helped MK-726InstallationInstr i can not upload it to the site but this one had the information I needed with setting up the fax sold me what to enter for instructions in the fax machine.
allan
02-19-2021, 08:50 PM
So you will be the newguy forever?
tsbservice
02-19-2021, 08:56 PM
Not required.
He is ED ;)
