View Full Version : c364e firmware upgrade
afonsolaw
02-24-2021, 12:58 PM
Hi all. Trying to update my c364e. Using a 2gb fat32 USB. Placed the files inside the A61F0Y0 in the root of the USB. When i plug usb into service port (power down machine, insert usb, power up machine.) I get a invalid external memory error. Any assistance appreciated.
48409
Woxner
02-24-2021, 01:23 PM
Open the folder and transfer all the files in the folder to the root. Nothing else on the usb.
afonsolaw
02-24-2021, 01:43 PM
Tried that with mult flash drives.
Synthohol
02-24-2021, 01:47 PM
do a system data clear in service mode then try again.
also just to check, the root of the flash drive looks like this right?
afonsolaw
02-24-2021, 01:52 PM
Will try the data clear. Yes. Looks right.
Thanks as always.
Khin Zaw
09-09-2022, 10:06 AM
48409
I got same shit. Did you get solution to that?
techsxge
09-09-2022, 10:23 AM
Reformat the USB Stick with rufus or gparted, not with windows.
ltdiniz
09-09-2022, 12:27 PM
Eu tenho a mesma merda. Você conseguiu solução para isso?
I use this program for Formatting and it works 100%.
You can format via cmd as attached step by step.
Follow Link
https://we.tl/t-mhGW7xoxHF
adfgdf
09-12-2022, 08:24 AM
As mentioned before,
check that the USB stick is formatted in FAT32 and has is up to 8gb storage,
leave all the files in the main folder (like D:\ ),
make sure it fits in correctly 100% , some times the USB stick doesn't make full/correct contact,
check if there is anything inside the machine USB port (protected by the small metal plate), like dust etc.
Try several times by pushing it in better, i have seen the same USB stick not working sometimes for it was not making the right contact.
Good luck!
copier tech
09-12-2022, 09:27 AM
Does the machine come to ready if you restart the device without the fw USB pen connected ?
Kenny
09-12-2022, 10:25 AM
48409
isnt A61F0Y0 mono machine firmware?
latest C364e firmware is meant to be - A5C10Y0-F000-GDR-M1.exe
EDIT: my bad i didnt see the OP was back in 2021
emujo2
09-12-2022, 03:16 PM
Dittos to Kenny..The OP is trying to install the incorrect f/w..Yeah it's an old post, but the OP should have updated it with a "my bad". E
