View Full Version : C759/C659 noise
Hello,
Do everybody have experience sometimes the noise is occurred on this machine.
I checked the fusing unit and exit section, added lubricant.
However the customer reported the same issue, the meter is below 70K.
Any suggestion?
Hi,what kind of noises do you hear (metallic or plasticky)?
Does it often happen when it is not used for a long time?
They called these 3 days and only can hear on the first time, like a squeaking sound but very light volume.
They said it would be happened usually on idle status, 2-4 times each day.
Synthohol
02-25-2021, 06:04 PM
Turn off sleep mode and make the energy save 5 minutes.
This prevents the oil roller in the fuser from drying out too fast causing 80% of all squeals squeaks and clicking.
Just my .02.
Just my .02.
Thank you, let's try.
