KM-Bizhub 250 Abort Code?
  • joe1200c
    Hi -
    I'm working on a Kohica Minolta Bizhub 250 that is currently having copy & printing problems.
    The issue is that that if you attempt to submit a 5+ page document (by either making copies or printing) the device will only print 4 pages...then the LCD will continue to flash "Printing"...nothing happens and then the Abort Code "0x00E00317" is generated.
    The Drum & Developer weere replaced this past May and the unit operated fine for 6000+ copy/print jobs.
    Does anyone know of this error code?
    Thanks in advance for any help!!!
    --Joe
  • joe1200c
    Another Error Code
    Hi again -
    Just thought I'd update that I just received another error code: 0x00F00201.
    Any thoughts?
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      Both of those codes go back to the MFBS, and the memory. I would try the memory first. It would be great for you if you could take one from a working machine and swap them to see what you need to order.
      • ebm
        • Apr 2007
        • 183
        Check out bulletin TAUS0702279EN00 for 0x00F00201. Not sure if this will help w/0x00E00317, no bulletins for that one.
