C252 M1 Operation Test
  • D Colour
    • Oct 2008
    • 213
    Can anyone tell me how I do the tests on the C252.
    I have error code
    Amongst other things, it says to perform M1 Operation Check.
    Cheers
    James
    Everything that has a beginning, has an end.....
  • kmcopier
    PSP
    • Oct 2008
    • 183
    You don't have to test this ,replace M1 and your problem is gone.
    For getting the machine to work you swap it with one for the colors but than you get the fault if you use color on that one we had so far 6 cases
    • ebm
      • Apr 2007
      • 183
      I no find 47-mode type tests either for Konica C-series machines. Only running mode and sensor check.
      Please post if find something. I looking same thing to test motors/clutches when troubleshooting these machines.
      • D Colour
        • Oct 2008
        • 213
        I wanted to be sure the motor was definitely faulty. Anyway, it turned out to be, we swapped it with the Colour Developing Motor (M3), which is identical, and then it failed. Was just hoping that there was a much simpler way to test it. The Ricoh machines allow you to run tests for virtually everything without removing a cover.
        • D Colour
          • Oct 2008
          • 213
          Ok, got a new motor which sorted that problem. When putting the jigsaw back together, the copies and prints (also internal prints/test pages) are coming out blank. Have i missed something or done something wrong? There are no error codes.
          Cheers
          • kmcopier
            PSP
            • Oct 2008
            • 183
            Please check if you got a image on the transferbelt .is there no message on the display you got to have some P warinings.
            Check you connectors.are all pages blank or only black what about CMY?
            Is the image on the pc drums ?
            Gr KMcopier
            • D Colour
              • Oct 2008
              • 213
              No image on the transfer belt, no error codes, no P codes either! All connectors seem to be in and it happens on k C Y M copies/prints.
              I will check the drums this morning.
              • B0265
                • Jan 2007
                • 718
                If there are no P codes I would suspect a bad connection to the transfer roller unit.
                • accicopias
                  • Apr 2011
                  • 3
                  y. .. What happened?...
                  y. .. What happened?... i have the same problem... please tell something.
                  accicopias@acciopias.es
                  • Toxic
                    • 697
                    Try to check conectors and 2 red wires on HV board if you removed it before.
                    • ni311
                      • May 2008
                      • 658
                      Check the pink cable that came from the transfer roller to the hv board, the one with a white connector, that one can be easily pulled out.
                      The bigger machines does have this test mode, unfortunately, on smaller machines like C252 you won't find this function.
                      Konica Minolta Error Codes - Explanations and Solutions
