View Full Version : Miscellaneous Konica Minolta Bizhub c458 Printing problem
vikashkj
02-28-2021, 05:44 AM
I Have a Konica Minolta Bizhub c458. the printer is printing files distorted. but while trying to take copy the output is fine. can anyone give a solution.
I have attached the image also
EarthKmTech
02-28-2021, 09:10 AM
yep looks pretty screwed alright.
I'd hazard a guess at one of the ram chips going bad on the mfp board.
Do all the memory tests complete ok ?
copier tech
02-28-2021, 11:25 AM
I'd start by reseating all connection on the MFP board, especially the ribbon cables from the laser, then update the firmware.
vikashkj
03-01-2021, 11:12 AM
can i get the firmware
copier tech
03-01-2021, 01:13 PM
Sure, email us at this site.
www.copierfiware.co.uk
vikashkj
03-04-2021, 06:15 AM
www.copierfiware.co.uk (http://www.copierfiware.co.uk)
i tried firmware update and fixing the cables
still the same
what to do next?
tsbservice
03-04-2021, 07:42 AM
what to do next?
This?
vikashkj
03-04-2021, 01:10 PM
This?
Memory test are fine
vikashkj
08-14-2021, 08:16 AM
Mfpb board Also changed still facing the same problem
REGSIS
08-16-2021, 07:06 AM
PH unit or PH unit control board. Try to reseat 2 flat cables on the board first.
