View Full Version : kyocera 5053ci
tee
03-03-2021, 06:41 PM
I replaced the magenta dv unit and recalibrated.
prints and copies both have magenta distortions.
I am trying a primary belt next, anybody have a
Taskalfa 5053ci with images like these samples?
BillyCarpenter
03-03-2021, 06:45 PM
What's the page count on the DV's and DR's?
If I had to guess from the examples that you posted, I'd say it's a magenta drum cleaning problem.
Also, you need to run some solid test patterns. See below:
48496
tee
03-03-2021, 06:49 PM
70k
drums swapping changed nothing
BillyCarpenter
03-03-2021, 06:57 PM
If it were the transfer belit, I'd expect to see more than one color affected.
tsbservice
03-03-2021, 07:05 PM
Look like something badly with magenta developer unit - magenta drum unit combo. Why you changed M developer unit, what was your initial problem?
blackcat4866
03-03-2021, 11:10 PM
It sure looks like bad developer spacers to me.
Was it a new unused developing unit? Or a unit of unknown provenance? It sure does not look like a new magenta developing unit to me. =^..^=
BillyCarpenter
03-03-2021, 11:42 PM
I believe you but how did you determine this? It looks different than the bad spacers on my example that you pointed out. Thanks.
blackcat4866
03-04-2021, 12:11 AM
The way I understand it, when the spacers wear, the distance between the developing roller and the drum diminishes, and starts arcing. =^..^=
tee
04-05-2021, 08:35 PM
I fixed it by reconnecting and cleaning all high voltage connections.
blackcat4866
04-05-2021, 10:35 PM
Thanks to the followup, tee. =^..^=
