View Full Version : konica minolta bizhub 368e with pc 415 jam
brent
03-08-2021, 11:02 PM
I am getting a 16-01 jam code.. pretty much jams in the pinch of the sep/feed tire.. wont make it out of the drawer.. replaced all 3 feed and sep tires
with an aftermarket source.. not sure if that is my issue as it worked for 100 copies then crapped the bed.. also with that drawer when the paper lifts it
sometimes clunks around 300k on the tray. any ideas? I really don't want to replace the whole unit if you know what I meann.
thanks all
brent
Synthohol
03-08-2021, 11:07 PM
clean the one ways and scuff the shafts.
also adjust the actual tray door towards you so it (body of the tray) pushes in further. this will engage the lift coupler better and can put better pressure on the take-up on the paper.
blackcat4866
03-08-2021, 11:08 PM
Something like this?:
bizhub 658e with PC-415, J9901 and J20-02 (https://www.copytechnet.com/forums/konica-minolta/134475-bizhub-658e-pc-415-j9901-j20-02-a.html)
brent
03-09-2021, 03:59 PM
some good reading material. I forgot about the shafts. thanks you guys
I will check it out today
brent
brent
03-09-2021, 07:33 PM
ok I scotch brighted the shafts. still jams.. so I watched the operation with the lower right door open. and I see what its doing.. the paper is being lifted too high in the front of the machine and lower in the back.. so right off the bat when it feeds it is squewed . now to figure why the paper is lifting crooked.. which was the problem all along.. not really a paper feed issue but a paper lifting issue.. I see wires that look fine but obviously I cant make it lift and watch the lifting procedure or can i> what do you all think about this? thanks a mill
brent
brent
03-09-2021, 07:43 PM
I see a wire is off the track.. let me try to sort it before we go any further...
brent
03-09-2021, 09:50 PM
totally fixed it by the wire being re routed. I would have never seen it if I wouldnt have opened the side door and watched it lift crooked.
thanks for all your help!
blackcat4866
03-09-2021, 10:41 PM
PC410/415 lift wires (https://www.copytechnet.com/forums/konica-minolta/152184-pc410-415-lift-wires.html)
brent
03-09-2021, 10:49 PM
sorry for posting so much.. I see that when you pull the drawer open when there is a jam or paper in the tray. it is so heavy that it drops and that cable comes out of the plastic holder.. I wonder if there was a bulletin on this. or a field fix? like I said I am sorry for posting so much. it was fine till I added more paper and was going to test it..drawer came out paper dropped cable came out
brent
brent
03-09-2021, 11:07 PM
blackcat. you are awesome. you sure know how to navagate this page to put links up.. I really appreciate the link and the pics.
I feel good that it fixed it. then it didnt work. but hopefully this will work. cant see how it wouldnt.. all we need to do is keep the cables in the
holders.. thank you much
brent
