View Full Version : Miscellaneous Kyocera M3040idn printing problem
zalazXT
03-11-2021, 08:19 PM
Hello, i have a problem with my printer, tried everything i could, not sure what to do.
The problem is half of page is grey lines this happens even printing a blank page, if density is increased it gets much darker, and even makes whole paper background grey, left side gets very dark.
Any suggestions?
patrickjlc
03-11-2021, 08:23 PM
Could be a bad developer or charge roller. Cleaned the glass?
Can you upload a picture, and how many prints the machina has
Sent from my motorola one 5G UW using Tapatalk
zalazXT
03-11-2021, 08:41 PM
photos IMG_5071.JPG - Google Drive (https://drive.google.com/file/d/1WHM-ijzdHCjUcbiIugvyOloisLTOpoUQ/view?usp=sharing), IMG_5069.JPG - Google Drive (https://drive.google.com/file/d/1WZ-v1YYzNmDGPfXbCKXEIjA5MQBy6v7_/view?usp=sharing)
zalazXT
03-11-2021, 08:42 PM
Glass is cleaned, but this happens even with blankn page printed from computer
zalazXT
03-11-2021, 08:47 PM
Pictures IMG_5071.JPG - Google Drive (https://drive.google.com/file/d/1WHM-ijzdHCjUcbiIugvyOloisLTOpoUQ/view?usp=sharing)
Machine has 89K printed.
copier tech
03-11-2021, 08:56 PM
I guess you are not a tech? This is a basic issue.
You simply need to replace the drum.
patrickjlc
That looks like a bad charge roller, the grey thing on top of the drum. Remove it, and see it had the same marks. Could try cleaning it with a cloth and some cleaning solution untill you get a replacement.https://uploads.tapatalk-cdn.com/20210311/fe8d8ed67feb35160555e67cfafdf8fb.jpg
zalazXT
03-11-2021, 08:57 PM
I dont have much experience i know, thats why im asking for help :)
zalazXT
03-11-2021, 08:59 PM
https://uploads.tapatalk-cdn.com/20210311/162020e9d48e16eb4a5d300e0fa9b6d2.jpg
Not sure if its that bad
copier tech
03-11-2021, 10:33 PM
The Kyocera M3040idn does not have this type of charge roller.
patrickjlc
03-11-2021, 10:41 PM
The Kyocera M3040idn does not have this type of charge roller.Yes sorry, got confused with the 3550 and 3540 idn.
zalazXT
03-11-2021, 11:28 PM
https://uploads.tapatalk-cdn.com/20210311/fe50c0901b994ff487fdb502f41c4295.jpg
It has this roller
ntbann
03-12-2021, 01:31 PM
I wouldn't use cleaner on charge rollers. It can dissolve the outer coating making tor roller junk. Strait water works the best.
