View Full Version : what models from 4 series correspond to minolta c452
araven666
03-15-2021, 10:58 AM
Hello, I have 2 minolta c452 and wanted to buy a new one to rebuild both but the seller only keeps 4 - series at stock so I was wondering if parts from 454/554/654 are compitable
Having in mind IU , fuser , tranfer belt.
Thanks in advance
escalante
03-15-2021, 12:35 PM
Hello.
1.- The imaging unit is almost the same, the only difference is the developer
2. - The fusion unit is different is not the same
3.- The transfer band is the same.
In colors. The Bizhub C654_ C65e_C754_C754e
In monochrome Bizhub 654_654e_754_754e
Enviado desde mi Infinix X656 mediante Tapatalk
Toxic
03-15-2021, 02:02 PM
If you are not very expirienced with bizhubs i would not advice you to go to that adventure you planed.
You may spent lot of money with no result.
Way better solution is to order original parts, i just check in my price lists from KM, almost all is still avaliable for ordering.
It is little bit expensive parts and maybe not worth investing in that old machines...
copier addict
03-15-2021, 04:15 PM
Thanks in advance
There is nothing that will directly fit from a C454 to a C452. Besides the speed, they are totally different machines.
emujo2
03-15-2021, 04:16 PM
I just canceled 2 maint contracts as supplies/consumables are not available. Not everything is gone, but enough that I can't service contracted customers. E
araven666
03-15-2021, 04:34 PM
Thanks for the replies. I was hoping that the next gen was just improved version not completely different assembly. Thank you all for the help :)
allan
03-15-2021, 08:10 PM
I would rather in your case start looking at a C554e.
Drums and dev units on colors separate and much more cost effective that the image units used in the C452.
