View Full Version : C454e Toner low Sign
I have few C454e after replace toner still getting toner low sign didn't reset any issue please advise thanks
Phil B.
03-23-2021, 04:10 AM
OEM genuine toner?
customer replaced?
rrrohan
03-23-2021, 04:12 AM
I'd remove toner, run multiple full bleed test pages in that colour until it asks for toner to be replaced then reinstall toner cartridge
Sent from my Pixel 4 XL using Tapatalk
OEM genuine toner?
customer replaced?
Yes. but some is rechip
BillyCarpenter
03-23-2021, 04:18 AM
What do you mean by re-chip?
refill toner and new toner chip
BillyCarpenter
03-23-2021, 04:24 AM
I'd say it's a high likelihood that the chip is the problem.
It's a good thing that Phil asked. Saved a lot of time.
Phil B.
03-23-2021, 08:17 AM
so it's NOT OEM genuine
that could be your problem bucko
are you even a trained tech?
About ck1 Country:Malaysia
Contact
This Page https://www.copytechnet.com/forums/members/ck1.html
Statistics
Can't tell by your profile
I'm done
I noticed that the C454e ignores a new toner if a customer replaced it before actual toner end condition.
Solution:
1. ignore the false toner remaining prognosis
2. remove the toner and run full bleed color patterns until the MFP says "toner end" then re-insert the toner
patrickjlc
03-23-2021, 12:38 PM
Run oem toner and wont have any problems. Those aftermarket chips are hit or miss....
Sent from my motorola one 5G UW using Tapatalk
tsbservice
03-23-2021, 08:13 PM
I'm sure this is right strategy for C224e-364e which toners don't have chip. But don't have this model in field. Will it work if toner has a chip? Or machine will ask to put toner inside and refuse to work?
In my "EU" market region I can run a C454e/C458 even without a toner installed so it seems the MFP does not really care about the chip. This fix works for me, too.
tsbservice
03-24-2021, 09:05 AM
OK, got it. However I'm pretty sure on C250i series will not run without one of toner cartridges.
