View Full Version : C220 firmware update
m3a2r1
03-23-2021, 09:12 PM
Does anyone know where I can get the latest firmware for the c220? I need it for SMBv2 support.
tsbservice
03-23-2021, 09:21 PM
Unfortunately SMBv2 is not supported on this model series. You can use scan to internal FTP server behind your firewall.
m3a2r1
03-23-2021, 10:00 PM
So maybe something newer than 2011 which I have. I can't get working scanning with Truenas as storage (with smb 1 enabled) and active directory as authorization.
tsbservice
03-23-2021, 10:09 PM
So basically they(manufacturers) want to be selling something newer than model you have and Bizhub C220 is like 10 years old. Surprise - they will not make any effort into updates of 3 generation old model.
erayyurukel
07-25-2021, 09:15 AM
[QUOTE=tsbservice;1716202]Unfortunately SMBv2 is not supported on this model series. You can use scan to internal FTP server behind your firewall.[/QUOTE
I need c 220 firmware update program, if you have it, can you send the file?
e mail: eryrkl@gmail.com
copier tech
07-25-2021, 10:45 AM
With SMB v1 enabled you should be about to scan via SMB OK.
We have a few clients that still scan to Win 7 machines without any issues using the C220 series.
We can supply the latest firmware should you require it please contact us at the links below.
