Sharp AL-1540CS L-1 error code
  • Cheeto
    Not a sharp tech, whats the L-1 code for?
  • Project Warder
    Uhm, i'm not too sure on it, but i'm pretty sure it has to do with the laser unit, or it's connections. I'll have a look and see if i can find a manual anywhere for it, although i've only ever worked on one AL series machine so far. If no luck, i'll see if i can find out from Sharp on Monday. We are a service dealer, so I should be able to find out.
    Actually, come to think of it, i'm not entirely sure that model is here in Australia. Hmm, if it is anything like the AL-1220 (although that one is Colour ?) then I might be able to relate the code from that. Hmm, not sure. I think i spoke too soon! Hahah, i'll still see what I can dig up on it, or even just generally the error code itself.
    Good luck.
    • tonerdude
      You have a scanner problem - didn't leave or come back to home, scan overload or cable off or drive problem. - Good luck
      • kiat
        L1 00 Feeding is not completed
        within the specified time
        after starting feeding.
        (The scan head locking
        switch is locked)
        1.unlock Scanner unit
        2. chang connecter
        Scanner unit
        good luck
        SOMKIAT_SHARP_SERVICE@HOTMAIL.COM
        fr..technic sharp in thailand
        • brade
          on the left side of the copier, under the scanner, there is a clear plastic dial that locks the scanner in to place for secure transit when moving. turn it to unlock the scanner
