View Full Version : Task Alpha 3252 Sep roller flat spots/noisey
dickierock
03-25-2021, 01:38 PM
Hi, we seem to be replacing these quite often with flat spots. Also noisy due to vibration.
The only bulletins I came across are for cassette warping where the trays are very full but haven't test this yet.
Any know fix for this issue out there? Thanks.
JR2ALTA
03-25-2021, 01:44 PM
Are they from the PF-7110 (trays 3,4)? That bridge unit has had several modifications I'd just order the whole deal.
BillyCarpenter
03-25-2021, 02:06 PM
blackcat, while he didn't specifically mention flat spots on the separation roller, did have this to say:
"For 0533, 0534 we've had to increase page separation. You've probably had to adjust page separation before. Decreasing the spring tension increases the page separation. I think of it this way: More spring tension makes the separation roller follow the feed roller more. Less spring tension makes the separation follow less, resisting multiple feeds." -blackcat
Just curious, what is the page count on the tray in question?
dickierock
03-26-2021, 09:24 AM
Have it on one PF7100, but also occured in the standard trays 1 + 2 on other machines. Have seen it in also mono 6002i models.
