View Full Version : Konica 951 dev come with copy
DoctorEv
03-26-2021, 04:21 AM
Hi guys, I need yours help. PRO 951. Copy out with little bit developer on the copy. And after 100 copies lot of developer inside of machine. I change devunit, drum, main charge, transfer unit with belt, descharge, HVPS board (for transfer sec) may be somebody had the same problème ? Please help me
allan
03-26-2021, 05:55 AM
Try switching off the drum potential sensor. SW 6 bit 7. Just an idea. Not sure what that can do to the charge value if its faulty.
lartis.aineias
03-26-2021, 07:27 AM
Hi guys, I need yours help. PRO 951. Copy out with little bit developer on the copy. And after 100 copies lot of developer inside of machine. I change devunit, drum, main charge, transfer unit with belt, descharge, HVPS board (for transfer sec) may be somebody had the same problème ? Please help meTry to change HV1
I had same problem. I solved with HV1
Στάλθηκε από το SM-G975F μου χρησιμοποιώντας Tapatalk
copier tech
03-26-2021, 09:46 AM
Strip & clean all the contacts, blow out all stray toner & developer this may help stray dev causes shorts.
DoctorEv
03-26-2021, 01:11 PM
Thank you!! I will try all advices and last, HV1)) because it's very difficult. 5 wires go inside of machine without connectors;(
DoctorEv
03-26-2021, 01:12 PM
Thank you!
DoctorEv
03-26-2021, 01:14 PM
Try to change HV1
Thanks, I will try!
DoctorEv
03-26-2021, 01:15 PM
Ok Thanks! I will tray !
apostlegato
03-30-2021, 10:28 PM
951 has a transfer belt?!? Oh the days when you could just turn the light off in the room open the door and key the door switch and watch for the arcing. I am surprised, I assumed the high volume monochrome machines would still have corona wires.
DoctorEv
03-30-2021, 10:47 PM
You can check SM
