View Full Version : Konica 7155
Vesigoth
11-21-2008, 01:58 PM
The lead edge registration is off by one inch when original is fed through the ADF and the display is not properly alligned such that when I touch an option on the screen it goes into another option. If you know how to adjust the display and how to adjust the ADF lead edge registration please advice. Thank you.
ebm
11-21-2008, 08:49 PM
Control Panel adjustment is in Key Operator mode.
ADF timing adjust is in 36-mode. Might be hard to adjust if one inch off. Check for mechnical problem also (clutch,rollers,etc.).
tech1569
11-21-2008, 09:45 PM
Hope this helps you out.
Konica 7155 Force65 7165
RapidShare: Easy Filehosting (http://rapidshare.com/files/166073069/Konica_7155_Force65_7165_Service_Manuals_Menu_Driv en.zip)
RockETop
11-22-2008, 03:31 AM
Straighten or replace the black mylars on the black paper guide under the ADF. They block light to the sensors.
