View Full Version : 4/4e series paper size on tray
jwai
04-01-2021, 05:29 PM
Hello,
I found the bizhub 4/4e series have common issue below:
The tray 1 often have auto paper size detection error, place A4-> display 8 1/2" x 11" , place A3 -> display 11" x 17".
I tried to test the paper size detection sensors by exchanging them with tray 2 however the same result occurred.
Have any idea about this?
copier tech
04-01-2021, 05:41 PM
Hello,
This is a know issue, the wire on the connector breaks, you need to replace the small loom.
Synthohol
04-01-2021, 05:44 PM
Could it also be the marketing area is not set correctly?
jwai
04-02-2021, 04:36 PM
the 4 yellow wires of the sensor on the middle of the cassette section?
jwai
04-02-2021, 04:40 PM
They are " others 2 " on marketing area.
I found it is only happened on tray 1, tray 2 never.
copier tech
04-02-2021, 04:44 PM
Yes.
jwai
04-02-2021, 04:47 PM
Yes.
Thank you,
can't imagine these wires would be broken without impact.
Phil B.
04-02-2021, 04:49 PM
Thank you,
or somebody not pulling the connector properly .. never remove a connector by grabbing just the wire harness
jwai
04-07-2021, 01:47 PM
I checked the connectors and 2 wires loosened,
it seems nothing happened on 8 series.
Toxic
04-07-2021, 03:33 PM
Probably because most users use tray 1 more often.
I have only 1 case and it happened because user do very much id card copy but they copy one side then put back paper to tray 1 and copy 2nd id card side :)
Too much open-close tray will over time damage this wires.
tsbservice
04-07-2021, 03:43 PM
Then you can go and setup for their convenience copy settings for printing ID cards directly without this archaic paper rotation :p
jwai
04-07-2021, 05:09 PM
Maybe the cause that I guess:
The CD sensor holder is set on one screw with spring, can slide front and back a bit distance.
But, the harness is installed so tight on the bracket, that yellow wires are easily to tear off.
copier tech
04-07-2021, 05:23 PM
Yes, exactly this. When installed at the factory there was not enough play in the cable plus the cable ties were too tight.
Toxic
04-07-2021, 06:37 PM
Few years ago i sold them C227 and take that C224e (count as few hundred $), soldered few broken wires of paper sensors and lease that machine, still going strong.
Ofcourse i show them how to copy id card in proper way, without need to put paper back to tray for second side :)
tsbservice
04-07-2021, 06:52 PM
C224e over C227 all day long :)
I'm guessing those clients are too stuborn to learn something new I have many of them and sometimes they really deserve what they have.
