diwakar
04-04-2021, 03:46 PM
Hello everyone !
I am sure you all must be safe and sound.
Recently, there is a problem with our Konica Minolta C258. Here are the system and paper settings first:
270 GSM art card
12x18 inches
Bypass feed
Thick 4 setting
1200 dpi print
Now, nature of the problem:
Dis-colored band on the edge which is coming out first from the printer
Attached images for references
Methods already tried:
Cleaned the machine inside out including rollers, Image Transfer Belt, Laser unit, lenses, inner rollers, by pass tray, fusing unit etc.
Changed the first transfer voltage for CMYK to -7 from -6 (we did -6 because when set at 0, there was shadow printing issue and -6 resolved it)
Initialised image stabilisation and gradation adjustment two times for both 600 dpi and 1200 dpi
But, the problem still persists, if anyone can take a look and let us know what could be the issue.
Thanks and regards,
270 GSM art card
12x18 inches
Bypass feed
Thick 4 setting
1200 dpi print
Thanks and regards,
