View Full Version : Prints are peeling on the edges on Bizhub C364 & C454
Hishamawada
04-10-2021, 09:19 AM
Hello,
When printing on stickers (thick 2) and 300 gsm (thick 4).
Tried slowing the speed of the fixer and still same , tried increasing the temp also same .
Any ideas what i could do?
Sent from my SM-G610F using Tapatalk
Max
04-10-2021, 10:10 AM
Make sure it's not inkjet/photo paper. Or the pressure is no longer sufficient due to worn out fuser. Compatible toner?? If so, melting point probably different.
Hishamawada
04-10-2021, 07:48 PM
300 gsm media is normal glossy paper and the stickers are for digital printers . yes compatible toner is used in both machines . Should i just increase the fixing temp for this specified thickness ?48893
Phil B.
04-10-2021, 08:25 PM
300 gsm media is normal glossy paper and the stickers are for digital printers . yes compatible toner is used in both machines . Should i just increase the fixing temp for this specified thickness ?48893Ditch the crap toner.
slimslob
04-10-2021, 09:00 PM
Not only different but inconsistent. A variation as little as 1 degree C in the melting point can be the difference between fusing properly sticking to the fusing roller/belt/sleeve. Use only Genuine KM supplies and parts. Otherwise as the old Fram oil filter says,
https://www.youtube.com/watch?v=Ij1yDpfZI8Q
