Bizhub c360 black quality issue
  • wynter17
    • Mar 2019
    • 33
    Hello,i have the followinh problem with a bizhub c360,everything was replaced, image unit,transfer belt,toner,developer unit,and the problem still persist.
    Does someone know what could be the problem?
    Thanks in advance
    Sent from my SM-G980F using Tapatalk
    Re: Bizhub c360 black quality issue
    Thanks in advance
    Check the PTR.
    Also clean the laser slit glass for each color.
    • wynter17
      • Mar 2019
      • 33
      Check the PTR.
      Thanks,the laser glass was cleaned
        are they using crap 3rd party toner?
        what about the PTR?
        • wynter17
          • Mar 2019
          • 33
          No,it is oem toner,everything is oem,sorry but i am not familiar with "ptr".What part is that?
            Primary Transfer Roller
            • wynter17
              • Mar 2019
              • 33
              It was replaced with the transfer belt,i also tried with another tranfer unit,but nothing changed
                are you sure the PTR holder wasn't cracked/mis aligned
                • wynter17
                  • Mar 2019
                  • 33
                  Yes,we have another c360 and i rrplaced the whole transfer unit but its the same
                    • 14523
                    Have you pulled the new black dev unit out again to check if it has dumped? What is the life of the other drums? It is possible for an over yield drum to cause issues in another colour.
                    Check for something blocking the black laser slit. Check the high voltage traces in the back for arcing.
                    • Toxic
                      • 697
                      Image unit you mean drum unit ?
                      OEM drums or compatible and did you replace all or just specific color?
                      What color developing unit replaced?
                      If i see good you have problem with black color mostly?
                      If i must guess i would say this is some problem related to developing unit K.
                      PS:Check this topic
                      KM bizhub C360 black fading in and out
                      • tsbservice
                        Field tech
                        • 7981
                        Thanks in advance
                        When you said Replaced I guess you mean "replaced with parts from working machine not new parts".
                        Because the price of new belt,drum, dev unit etc will exceed easily price of used C360 machine.
                        In that case your used black unit TCR value is too high you can check it in service mode. Then machine wont ask for toner and will dry developer unit after a while, maybe a few days of usage.
                        P.S.
                        You should better attach CMYK halftone patterns at full density and at 128.
                        • wynter17
                          • Mar 2019
                          • 33
                          P.S.
                          No,i replaced with new parts,in my country these parts are cheaper,all oem,the tcr value is at 6%
                          • wynter17
                            • Mar 2019
                            • 33
                            PS:Check this topic
                            Yes image unit=drum unit,all oem,i replaced only the black one,the problem is only with black
                            • wynter17
                              • Mar 2019
                              • 33
                              I should check the other drums,those are a bit used,i checked the dev unit,nothing wrong with it
