View Full Version : C224 fax kit
Hi everyone,
I have one fax kit FK511, attempt to install on one C224 ( F/W G00-XX ).
When I restarted the machine, CB003 display during the preparing scan/fax.
So I check both USB and signal harness and plugged them again, still same issue.
So I took this fax kit and installed another one C224 ( F/W GD5-XX ), it worked normally without any error.
What's the reason about it? Thanks.
copier tech
04-15-2021, 04:30 PM
Hi everyone,
With both machines being on different firmware version I'd start updating the firmware on the C224 with the error.
emujo2
04-15-2021, 05:23 PM
It's also very easy to bend the pins on that connector...In my experience most fax codes on install are caused by this..there is also a small switch on the fax board that configures if for fax 1 or 2..Ensure it's set to 1. E
This fax kit had been removed from a C364e fax 1 slot.
emujo2
04-15-2021, 06:40 PM
well maybe you should not have posted that both machines were C224s..There is a big difference between the 2..I now support the inco firmware on the fax board. E
copyman
04-16-2021, 12:52 AM
Even if machine has error code you can wait awhile and eventually enter service mode. Compare setting between the two machines. Also can initialize the fax unit in service mode.
