View Full Version : c6500, cyan in gray prints and copies
mick75
11-24-2008, 03:55 PM
I've got a C6500, test prints and customer prints have a blue tint when printing anything with gray, I replaced the gamma sensors and re-did all adjustments, tried several out put profiles and calibrated the Fiery. I still get too much cyan in everthing but it is most noticable in gray. If anyone has any thoughts on this issue please let me know.
kmcopier
11-24-2008, 08:45 PM
I think you print rich black. check your settings for pure black and this will solve your problem. it in colorwise
stathistec
11-27-2008, 07:39 AM
probably you should reduce the exposure of cyan.
bigmark
11-29-2008, 04:24 PM
try calibration on different media types. some times calibrating on different media types will help. then apply it to all media types. Are we talking Creo or Fiery here?
twinax
12-01-2008, 03:03 PM
Hello,
I think that your problem is not the engine but the controller (EFI device).
First of all you need to know if your document is CMYK or RGB?
Check your color with PITSTOP is there a true black (or grey level)!
For CMYK :
The GCR should be on "Source"
also remove all input profils (profil = none)
RGB
Change the grey condition (windows under RGB profil)
For a best result you can print with Line1 instead of DOT1.
If you are sure about engine adjustement don't touch the engine!
Kind regards
texchar555
01-19-2009, 11:51 PM
Dip SW 12 – 4 set to “1” Improves Gray Balance
a) Gray is reddish when copying (Insure 12-5 is set to “0”
b) Firmware MUST BE 15 +, Turn off the C6500 then back on (Let it stabilize),
Perform Gamma Offset, Gamma Sensor, & Auto Gamma in order to take effect
c) Set to “0” for normal
Dip SW 15-7 set to 1 Enable LDAP function (Optional) try this
Si@danwood
01-27-2009, 06:30 AM
Try switching colourwise off in simulation had a similiar and this cured it stone dead:)
mick75
02-12-2009, 06:10 AM
thanks it was a controler issue the colourwise trick did it.
