View Full Version : Konica C8000 press finisher problem
mshabban
05-28-2021, 01:06 AM
Hello all, I have issues with Konica c8000 press over jamming in the finisher , I have cleaned all rollers , cleaned all sensors but after a few runs , then it starts jamming again, wasting a lot of papers and ink , so I wonder if it’s possible to disassemble the machine and make it work without the finisher well and if it’s possible, what would be the procedures and the necessary NVM reset codes ,will be grateful for any tech advice .
Synthohol
05-28-2021, 01:54 AM
The best advice is to look up the jam code.
tmmdmmm
05-28-2021, 05:04 AM
J code is needed, as well as whatever finisher is installed. Even with everything clean, ive had everything from faulty sensors to sensors being just enough out of position its triggered from the metal below it
tulintron
05-28-2021, 02:43 PM
Enable DIPSW 11-7 to ON to show J-xxxx. It is easier to locate the error.
Try other paper formats.
Try heavier paper weights.
