View Full Version : Bizhub C258 code C-2152
tsbservice
05-30-2021, 11:29 AM
Got call for this error C2152: Transfer belt fault at initial position return. Obviously it won't go away upon trouble reset.
I'm going with another ITB unit and plan to clean inside machine and infamous PS39 sensor. Other than that what may be expected? 1st transfer pressure clutch (CL5) replacement looks like real PITA though.
As always great Thanks for any tips and tricks from experienced.
rrrohan
05-30-2021, 12:30 PM
U might be lucky and not need to change clutch. Otherwise a 5 min job will turn into a hour
Sent from my Pixel 4 XL using Tapatalk
blackcat4866
05-30-2021, 03:10 PM
Bizhub C360 w/C2152 error (https://www.copytechnet.com/forums/konica-minolta/62739-bizhub-c360-w-c2152-error-post1488313.html#post1488313)
bizhub C224 has C2152 error code (https://www.copytechnet.com/forums/konica-minolta/125378-bizhub-c224-has-c2152-error-code.html)
C554e with C2152 error (https://www.copytechnet.com/forums/konica-minolta/123826-c554e-c2152-error.html)
There's a photo in this thread from a C284. Not sure if it's any help:
https://www.copytechnet.com/forums/konica-minolta/152199-c284-c-2152-a.html#post1598053
At one time I loaded a photo from a C654e, ... I cannot seem to find it, but it's PS52 on the C654e. There it is!:
49296
tsbservice
05-30-2021, 03:31 PM
Thanks guys I already dig forum and definitely saw your picture BC. As this is relatively low metered and new machine I don't expect it being dirty but who knows. I have had this once and it was piece of plastic broken from ITB itself. Anyway it's 2+ hours away so basically whole day call and I don't need something stupid which I can miss on my way.
tsbservice
05-31-2021, 07:18 PM
Solved. ITB primary charge roller lever broken - fixed plus PS39 need cleaning.
rrrohan
06-01-2021, 01:50 AM
I didn't thing you could over rotate that gear that drives the colour transfer rollers. Doesn't it just switch between engaged and disengaged. Wonder how it broke
