View Full Version : bizhub C250i foggy backgroud printout
jwai
06-09-2021, 12:59 PM
Hi everybody,
One customer reported that the color printout has a bit foggy background, compare with B/W one.
The color drums have 60% something and 30% something on black drum.
The machine takes 40K color and 140K black counters.
Any idea about this issue? thanks.
Synthohol
06-09-2021, 01:49 PM
i dont see anything wrong.
you can always reset and stabilize then do the gradations 3 times each and see if it changes but frankly, im missing where the problem is.
jwai
06-10-2021, 06:04 AM
Sorry, I sent a new sample for reference.
CP-1015
06-10-2021, 06:35 AM
Is your cyan TCR-value ok?
Dickie
06-10-2021, 09:50 AM
I believe there is a firmware upgrade to cure a problem with too much cyan.
A previous firmware upgrade caused the issue and it was then upgraded again to cure the issue
This was on Develop but I assume KM initiated it.
Albonline
06-10-2021, 12:52 PM
the cyan developer looks over toned. what do the halftone outputs look like?
Cantechman
06-10-2021, 03:54 PM
Hi everybody,
you can try this:
change switch 153 bit 6
under pcl driver:
quality tab/quality adjustment/other/turn pure black off
jwai
06-10-2021, 04:36 PM
CYMK all 6.XX%
Synthohol
06-10-2021, 09:14 PM
before all that, try just simply calibrating it like i suggested above.
tsbservice
06-10-2021, 09:57 PM
What's FW version? Your threads seems always lack valuable/basic information.
Pulling other tech teeth is so much uncomfortable :eek:
Phil B.
06-10-2021, 10:13 PM
Pulling other tech teeth is so much uncomfortable :eek:Hell the " Dentist " doesn't mind one bit.. for those that get queasy at the sight of blood don't watch![emoji38][emoji28][emoji1787]
