View Full Version : C450i Colour Drums
stan780953
06-11-2021, 05:01 PM
Hi,
Just wondering if anyone has tried using a black drum to replace a colour drum and if this has been reliable in the field. The C450i black drum doesn't fit but a black C250i fits ok with a couple of adjustment similar to the 8 series and there are chip available.
thanakon1995
09-29-2021, 06:31 AM
I have not tested If you have a chance, try to test. :)
Gift
09-29-2021, 07:04 AM
Thanks for the tip with the BK C250i drum - we use C308 BK drums but what we do is probably way more work, because you have to harvest different parts from the i-series unit.
sam_engineer
10-14-2021, 04:40 PM
Hello - currently need to replace the colour drums in a 450i.. can you give me more info on how to use the C308BK drums? Appreciate your help and tips.
Gift
10-15-2021, 07:20 AM
The differences between the units are mainly the rear cover + charger roller contact and the waster toner auger (differnet length) + nozzle thingy and - if I remember correctly - that "gearish" thing on the back on drum shaft plus that spacer. Chips from 8 series work, too. You can either harvest a C308 drum in order to refurb a i series unit (the quicker way) or strip the necessary part from the old i series drum and refurb the C308 drum and make it fit (the more thorough way). Whatever you decide, it is more work compared to COL->BK mod for the 8 series. I think the price gap between the 8 BK drum and i series BK drums do justify the effort.
Depending on the routine the time amount might be 10-30min/unit
Best thing is to mess around with some used units from the "bin department" in your shop first...
flippinsweet
11-05-2021, 11:24 AM
Thanks for the info Gift
I've just refurbed a C308k drum with parts taken from a used C250i colour drum which I need to fit to a C450i machine. Swapped the rear cover, charge contact, drum gear and front section, also snapper off the plastic stopper on the right hand side and fitted a new colour chip for the 8 series.
I've done this before but never had to fit to a C450i and noticed the part numbers for 450i / 250i drums are different. Do you know if this should work or if I'll need to swap the waste toner auger & nozzle you mentioned? Don't have any 450i drums in the office to play about with unfortunately!
Coggers
04-17-2022, 09:40 PM
Hi where did you get the drum chips from ?
uk based and we need these chips.
splblazer91
04-19-2022, 05:48 PM
I havent had luck with swapping i-series drums. They always seem to background.
tsbservice
04-19-2022, 06:27 PM
Please specify what you mean by swapping?
splblazer91
04-19-2022, 06:51 PM
Replacing an i series color drum with an i series black drum or vice versa.
tsbservice
04-19-2022, 07:09 PM
Only drum cylinder or you modified whole drum unit(ie making from black colour like 4 and 8 series) but it backgrounds?
Sorry for maybe asking too much questions but it has some specifics you know.
avecosat
04-20-2022, 07:53 AM
since series 8 you can't swap color drums to black ones without making some changes
Gift
04-20-2022, 09:17 AM
The chips are the same as Cxx4, Cxx8
