View Full Version : Konica C224e reboots, SSDB?
jonbonse
06-14-2021, 10:14 PM
Hi all
One of our c224e's has the rebooting with 2 shark fins. I have the SSDB on order but don't have the SSD firmware to load...
I understand I need to fit the SSDB then load SSD firmware.
Is this correct? If so, I'm hopeful some has the firmware?
TIA
blackcat4866
06-14-2021, 11:31 PM
AFAIK it comes fully loaded. =^..^=
jonbonse
06-15-2021, 07:15 AM
Thanks!
I have replaced the SSD Board before on a different machine doing the same thing but it made no difference.
tsbservice
06-15-2021, 08:09 AM
1. Replace SSDB.
2. Install the firmware.
Done.
jonbonse
06-15-2021, 08:11 AM
1. Replace SSDB.
Done.
Thanks, I just need the SSDB firmware then which is the only bit I don't have 😩
B0265
06-15-2021, 08:15 AM
1. Replace SSDB.
2. Install the normal firmware, the latest SSD fw should already be on the SSD board.
jonbonse
06-15-2021, 08:21 AM
1. Replace SSDB.
Ah perfect! Thanks a million 👍🏻
REGSIS
06-15-2021, 05:22 PM
I always install latest Mass production FW which is M1 for this model. It has SSD FW in the package.
jonbonse
06-15-2021, 05:34 PM
Thank you
The latest full firmware I have is named 'A5C10Y0-F000-G20-M1-970'.
I'm guessing as it has M1 in the name I'm all good...
copier tech
06-15-2021, 08:10 PM
Thank you
49458
