Corbane11
06-28-2021, 03:22 PM
As of recently, I run a Konica Minolta c1060, haven't posted on here before.
I'm trying to print a portrait double sided brochure on regular copy paper. As far as I can tell the paper settings are okay. The issue I'm having is I can make it print portrait just fine but it won't be double sided, alternatively I can print double sided but it comes out in landscape. In the Layout tab, if I keep it on Normal I can override it to portrait every time, however there is no setting in Normal to achieve double sided printing. If I switch to Gangup, I get the double sided printing I want, except now it comes out landscape when I want portrait and there's no setting to fix it. Basically, I can get one but not both at the same time, leading me here.
I could print one side and then the other, but since I need a lot of copies it would be tedious.
If anyone has a solution to my problem I would greatly appreciate it.
