View Full Version : How to set https from computer to copier interface?
adecanmin
06-29-2021, 12:10 PM
Gentlemen.
How is that done? I installed a self signed certificate. Enabled SSL and made some other setting changes needed. Still no https.
Security tab Enable SSL
Select a mode from the [Mode Using SSL/TLS] drop-down list. ...
Select an encryption strength from the [Encryption Strength] drop-down list.
Select the checkbox of the SSL version to be used.
Click [OK]. ...
Click [OK] on the setting complete screen.
You can access http or https by ipaddress
adecanmin
06-29-2021, 12:54 PM
Click [OK]. ...
It is enabled.
Under protocol settings I see nothing for https. Not sure if it matters. I tried two different Konicas and could not get https to work. Is there a soft switch I need to change for HTTPS? I wouldn't think so because everything seems to be done under administrator. I followed the user guides. Looked at various videos. Everything is set up but still no go.
It is enabled.
Can you access through http ?
adecanmin
06-29-2021, 01:30 PM
yes.
It has the warning in red. SSL is not set-up Please set up SSL after admin logins to secure safety of the information. If I use https with the ip I can't get in. There has to be someone that has setup HTTPS successfully on the interface. Especially in an enterprise company where the I.T. administrator would want HTTPS for communicating with the copier.
Try a different web browser
don't worry about not an issue
mojorolla
06-29-2021, 01:52 PM
Did you reboot the machine after installing the new cert ?
This is required on an current KM boxes
emujo2
06-29-2021, 01:53 PM
try from scratch again..delete the factory installed SSL cert. Create a new cert based on 2048/256, go into SSL and enable both user and admin, select all 4 radio buttons. You browser should pop up the new "warning". E
adecanmin
06-29-2021, 06:41 PM
Thanks I'll give it a try and post back my results
