View Full Version : C1070 C2070 FUSER
methogod
07-02-2021, 05:37 PM
any one have a part number for the main frame. Doesn't look like its in the parts book, wonder if anyone has a part number? or a junk fuser i can buy?
copiray
07-02-2021, 06:07 PM
Buy a junk machine or try to fix it
blackcat4866
07-03-2021, 12:03 AM
Ouch! How did that happen?
No part number in the parts manual. It'll take you all day to swap over everything, assuming you find a source for that part. If you have the time ... and a medium sized ball-peen hammer, and a block of hardwood ... maybe you can hammer it out without deforming it too much. Most techs probably would not spend the couple days it will take to hammer it out, with unpredictable results.
I spent three days on a bent Kyocera scanner frame, against my advice, and to my surprise I was able to get decent focus. Left up to me, I would have taken the scanner from a donor. =^..^=
wjurls
07-08-2021, 11:21 PM
You can probably pick up a EF-103 (envelope fuser) on the cheap and swap the harness for the upper temp sensor connector with the damaged unit and you'll be back in business.
