View Full Version : Faded prints to the top of 12x18 prints.
positiveg
07-09-2021, 04:27 PM
The C454 is printing faded to the top. Not sure what's causing it if it's the fuser, basically new 50%. Or the transfer belt. Please see image to get an idea what I mean. Thanks https://uploads.tapatalk-cdn.com/20210709/f9add651b18cd007aa419db02fd55fc5.jpg
Sent from my SM-G955F using Tapatalk
copier addict
07-09-2021, 04:44 PM
If you haven't already cleaned the printheads, start there. Then stop the machine the the middle of print and check if image is faded on transfer belt.
srvctec
07-09-2021, 05:00 PM
Is the lead edge at the top of the page? If so, then probably dirty P/H. Best way to test is to run halftones set at 100 for each individual color Black(1PC), Cyan, Magenta, and yellow. If they all present the same issue, it's dirty P/H most likely.
Just took this photo yesterday on a similar call for a C368.
https://i.imgur.com/gvwztkL.jpg
Walterj
07-13-2021, 05:43 PM
good day
It is very likely that the error that your machine presents when printing is due to the PH Unit, I recommend you not only clean the filters with the pad, but also remove the PH Unit and perform an internal cleaning with dry cloths.
Greetings.
