View Full Version : Portuguese firmware for BH 284e
ltdiniz
07-12-2021, 01:20 AM
Good night !!!
I need the firmware in Portuguese for BH 284e_224e
My equipment has FW A61F0Y0-0100-G00-C8
What would be the Portuguese version?
emujo2
07-12-2021, 07:16 PM
Good night !!!
From my experience, changing the marketing area gave you the different languages..and there is not much difference..
If you set the marketing area to US, spanish is available, (again I don't know if Portugese is the same), but the paper default is LT LEF, changing to others 5 would still give you US and Spanish as a selectable language, but A4 LEF is the default paper size. Also changing the marketing area may put your consumables into an over life condition...E
ltdiniz
07-12-2021, 09:23 PM
Thanks for the tip!!!
My client's problem is that due to the same being Brazilian, he wanted a Language on the Panel with PT to facilitate the operation of the user functions, I thought I had a FW Language for this BH284e model.
emujo2
07-13-2021, 01:02 PM
I believe the language selection options are under utility/user/system settings/language..There are also language selection in the driver. E
Walterj
07-13-2021, 05:34 PM
Good night !!!
good day
When rewriting the FW it gives you the options to choose the languages ​​you need to appear in the user interface (operation panel).
If you require any version of FW you can write to me at walvaradocruz@gmail.com
Greetings.
tsbservice
07-13-2021, 05:39 PM
good day
Greetings.
I think Walterj is correct. I was going to write the same.
emujo2
07-13-2021, 07:03 PM
good day
Greetings.
That's good info..after 20 years I've never used the language portion on a f/w update..Good to know. E
ltdiniz
07-14-2021, 12:14 PM
[QUOTE = Walterj; 1831875] bom dia
Ao reescrever o FW ele dá a você a opção de escolher os idiomas que você precisa para aparecer na interface do usuário (painel de operação).
Se você precisar de qualquer versão do FW, pode escrever para mim em walvaradocruz@gmail.com
Saudações. [/ QUOTE]
Hello everyone, I performed this procedure mentioned above Walterj already in Color C224e models and it was successful, but in this BH 284e B&B Equipment using the attached process and even with Multilingual Firmware the PT option does not go up in the FW process.
[Release version]
<554e/454e/364e/284e/224e MFP firmware>
*This firmware can use for Multi-Language. (Multi-Language firmware is the same as this firmware.)
Model Program Name Current Ver. New Ver. Program File Name
bizhub 554e/454e
/364e/284e/224e
MFP firmware G00-E4 G00-G9 A61F0Y0-F000-G00-G9.exe
tsbservice
07-14-2021, 12:49 PM
[Release version]
bizhub 554e/454e
/364e/284e/224e
Try another FW plus yours is old FW version.
ltdiniz
07-15-2021, 01:17 AM
[QUOTE = tsbservice; 1832575] Tente outro FW, além da sua versão antiga do FW. [/ QUOTE]
I'm going to get information and nuscar any contact who has the uMultiliguagem firmware in PT.
But thanks for the tip!
If anyone has can send me a download link on the e-mail ltdinizudia@gmail.com I appreciate it.
avecosat
07-15-2021, 06:40 AM
The last firmware with portugues language is G20 - M0 MSG99
ltdiniz
07-15-2021, 11:30 AM
Exactly this version Solves my problem with the Portuguese update.
Whoever is this Firmware my e-mail and ltdinizudia@gmail.com and I am willing to negotiate values or in exchange for documentation and firmware that may be available.
rogermatsunaga
08-16-2021, 09:37 PM
Hi, guys!
I'm also searching for this FW in portuguese or latest version.
Itdiniz have you already found it?
tulintron
08-17-2021, 01:13 PM
Hi, guys!
Itdiniz have you already found it?Itdiniz and Rogermatsunaga, this line of black equipment was not sold in Brazil. There is no Portuguese update for these models
ltdiniz
08-19-2021, 01:04 AM
Really Tulintron this model was not sold in Brazil I know that but I believe that KM has made a base update PT in some FW Multilingual in the update pack, but by the way this version doesn't even exist in PT.
But since already thank you!!!
