View Full Version : Want to delete/format Kyocera HD-6 SSD Board
druckerteam
07-15-2021, 02:31 PM
Dear guys.
We have several Kyocera machines with integrated SSD Boards HD-6.
We have to delete the SSDs with a erasing software.
The boards have a special S-ATA port and I cant find a adapter to connect this SSD boards to a computer.
Here you can find a picture:
https://www.bechtle.com/shop/medias/5f800bb14c2f85143c097082-900Wx900H-820Wx820H?context=bWFzdGVyfHJvb3R8Njg2NTN8aW1hZ2Uv anBlZ3xoYTAvaDc1LzExMzYzMjcxODY4NDQ2LmpwZ3xjZTIxND FjODFkYzM5MDE2ODhiYjJhZWQ3MDgzYWE2MmUyZTliNWQxMjQ0 NmM4M2ViNGVmZTkyOGIxMGI0MjZk
Do anybody have a ideo how can i connect this SSDs to a copmuter?
Thank you in advance.
Regards, Paul
PrintWhisperer
07-15-2021, 03:29 PM
The 8gb SSD looks like PCIe NVME form factor. Try a PCIe adapter board for NVME SSD. Of course you will brick the machine probably when you format them externally. I believe that SSD has the boot partition. Let us know.
druckerteam
07-15-2021, 03:50 PM
Thanks for the reply.
I think it is a different form factor.
Attached is a pic of the SSD.
49719
I think NVME looks like this? Or I am wrong??
https://asset.conrad.com/media10/isa/160267/c1/-/de/002307989PI99/crucial-p5-1-tb-interne-m-2-pcie-nvme-ssd-2280-pcie-nvme-3-0-x4-ct1000p5ssd8.jpg?x=300&y=300&format=jpg&ex=300&ey=300&align=center
Regards, Paul
GeneOR95
07-15-2021, 04:01 PM
I don't know why you are using a separate application to format the SSD. The machine has a built in function to accomplish this.
Formatting an SSD
1. [System Menu/Counter] key > [Common Settings] > [Format SSD]
2. Format an optional SSD.
*: When an optional SSD is inserted into the main unit for the first time, it must be formatted before use.
Formatting will delete all existing data on an SSD.
*: This setting does not appear if the optional security kit is installed
PrintWhisperer
07-15-2021, 04:13 PM
49719
Regards, Paul
Not an Normal NVME connection you are correct. The type of SSD still not identified though.
Seems unlikely to be SATA at 8gb what would be the point.
PrintWhisperer
07-15-2021, 04:15 PM
Formatting an SSD
Mhmm and maybe run MM026 but I wanted to see what happened if he did it his way
GeneOR95
07-15-2021, 04:16 PM
Correct. This is an HD-6, an array of chips with a proprietary interface connector. I do not believe there are any adapters available for this connector.
I may be wrong but I haven't found any.
PrintWhisperer
07-15-2021, 05:12 PM
Damn proprietary.....
Ya I didn't pay close enough attention to the HDD he was referring. Too early for posting here I suppose:o
The 8gb SSD is like mSata connector BTW but not this.
druckerteam
07-16-2021, 08:45 AM
Okay.
Thanks guys.
I know that we could format it in the copier, but we need a erasing confirmation with the serial number of the hdd for our customer.
This is the point. So if there is no adapter we have to check it with the customer. Thank you very much.
Regards, Paul
tmaged
07-16-2021, 03:13 PM
I would have them pay for a new drive and hand them the old one.
druckerteam
07-20-2021, 09:41 AM
Yes, you are right. I think we will do like this.
Thanks fpr the replys.
Regards, Paul
KYO_OEM
07-27-2021, 10:38 AM
You can run "Data Sanitization" by system menue.
After "complete" message you can choose print out sanitization report depended to the system.
The Data sanitization function will delete everything!
