View Full Version : Konica C220 print quality problem
ferro10
07-19-2021, 01:16 PM
Hello everybody A customer reports quality problems printing on black. He says that wavy print (see file)
In My opinion The Problem is the BK Development Group.
Do you have other ideas?4974049741
Synthohol
07-19-2021, 02:00 PM
needs a new black DV unit.
tsbservice
K developer unit almost developer empty.
mandongo
07-19-2021, 05:30 PM
Black developing unit 100%.
I had the same issue. After replacing it everything was ok.
femaster
07-19-2021, 05:33 PM
Just to add yet another +1 for the K dev unit. Make sure K drum isn't over life as well, replace if it is.
ferro10
07-20-2021, 11:02 AM
thank you all
ok then I replace K dev unit
avecosat
07-21-2021, 01:02 PM
Also check the clutch of the dev unit K A0EDM20000
ferro10
07-23-2021, 10:25 AM
replaced Dev BK now everything works regularly
thank you all
copyman
07-23-2021, 05:16 PM
thank you all
Like other poster mentioned replace black drum as well or you will be back there when the developer dumps again from over life drum shorting out.
A lot of posts on this forum about "4 series dumping developer
ferro10
07-26-2021, 04:05 PM
For 4-5 days the printer worked regularly.
now the same problem has been presented
Now I try to change only the drum bk? or I have to change the dev bk again together with the drum?
PS: Can it be a toner hopper problem that does not download toner inside the dev bk?
femaster
07-27-2021, 03:30 AM
You will need to do both, including K dev unit. Replacing just the K drum won't get your developer back, which is now sitting in your waste toner box, along with the developer from the last dev unit.
avecosat
07-27-2021, 06:41 AM
Is the clutch ,I have had the same problem a couple of times
ferro10
07-27-2021, 07:23 AM
What clutch are you talking about?
Zesti
07-27-2021, 07:30 AM
Which toner are you using? sometimes bad toner also causes developer going in waste. How did you change dv only unit comes as whole... with drum.
ferro10
07-27-2021, 11:12 AM
The black toner is original
avecosat
07-27-2021, 12:28 PM
Is the figure 20 MAIN DRIVE SECTION in parts manual ref : A0EDM20000 .
Look in the manual pag 126 5.5.73 Developing clucth K CL6 for how to remove it .
ferro10
07-27-2021, 02:57 PM
OK thank
In your case you had to replace the dev bk too? In addition to the clutch
Todd Glenn
07-27-2021, 04:24 PM
Check to see if the K developer unit is turning, if its packed full of toner clear to the top, its usually a sign its not, and that clutch mentioned is bad. If you run with the cover open, and place your fingers on the k developer, should feel some vibration if the auger is turning.
femaster
07-28-2021, 02:03 AM
C220 has separate dev and drum.
avecosat
07-28-2021, 06:09 AM
OK thank
Yes because the developer is gone
thanakon1995
07-28-2021, 12:01 PM
Consumable!!!
49809
Zesti
07-28-2021, 01:19 PM
My BAD.....:rolleyes::rolleyes::rolleyes:
ferro10
09-15-2021, 04:43 PM
I updated this discussion
Replacing the CL6 + Developer BK everything works regularly
allan
09-15-2021, 08:40 PM
Did any one mention its the DV311K?
