View Full Version : Disabling Papercut
Valintine
07-22-2021, 04:19 PM
Hello
The boss just bought a Bizhub C458 to refurb. I found out it has papercut. Does anyone know how to uninstall or disable this? I usually work on Toshibas but the boss seems to be pushing the Konica Minoltas lately. Any help would be appreciated.
Joe
blinxwap
07-22-2021, 05:02 PM
Hello
JoeAnyway i know how is to remove the printer from the papercut server and then turn it off on user authentication
Sent from my Hisense U40 using Tapatalk
tsbservice
07-22-2021, 05:05 PM
You may want it starting from fresh. Enter service mode, system 1 - Initialization - clear all data. You will need to re-enable HDD and install Movie data though.
Valintine
07-22-2021, 05:11 PM
When I power the machine on it tries to connect to the papercut server. Shortly after it comes up with a message timeout. Nothing happens when I press the menu button. Is there something else I need to do to enter service mode?
blinxwap
07-22-2021, 05:13 PM
When I power the machine on it tries to connect to the papercut server. Shortly after it comes up with a message timeout. Nothing happens when I press the menu button. Is there something else I need to do to enter service mode?Follow trouble reset procedure once it popsup the key pad will display then go into service mode and initialise the mc
Valintine
07-22-2021, 05:17 PM
Thank you for the help. When I opened the front door to turn the machine off something told me to press the menu button and I was able to get into the tech rep mode and it is resetting now. Again thank you for the quick help. Have a great day.
emujo2
07-22-2021, 05:51 PM
If this does not solve the problem you can go into the open API settings and remove any registered applications. E
rrrohan
07-23-2021, 04:53 AM
if you press access it takes u to the standard user auth login screen, from there u can press menu then counter and so on
tsbservice
07-23-2021, 05:10 PM
Yes Papercut won't prevent to enter CE mode.
