View Full Version : Minolta CF3102, Etc. Scan set-up w/fiery
copyman
12-03-2008, 11:50 AM
When setting up scanning via FTP, the default format for scans is set to full color JPEGs or TIFFs. Most users prefer to scan their files to PDF files, however this needs to be manually changed each time the user scans. There does not seem to be a way to change this default from JPEG to PDF on the panel or via web interface. None of the web interface tabs give me an option to change this, but I am unable to login to the web interface via IE using the “sysadm” password to see if there is a setting for this. Am I on the right track? Can this be changed once logged in using the primary “sysadm” account? How can this setting be changed? Also, is there an easy way to reset the password under the “sysadm” account?
Thanks in advance
B0265
12-03-2008, 01:53 PM
It's been a while, but I think you do like this:
In scanner mode, make the desired settings then press Utility > Input > Reset Mode > Set-up Mode > Input > Enter.
