View Full Version : KM C6500 and oce CS650 toner
brian155
12-03-2008, 02:14 PM
gents, could anyone tell me if the toner for both C6500 and CS650 engines are the same .i.e. that the bottles physically fit rather that the chemical make up. i would like to run both engines but only want to stock one set of consumables.if not then i will change the toner bank completely,any information would be greatful thankyou.
DadO
12-04-2008, 09:00 AM
If engine is the same then toner should be compatible.Oce got whole color tehnology from konica minolta even tho i do not understand why did they do that just like that to give a way technology that is god knows how much expensive then techn. of B/W machines.....
brian155
12-04-2008, 10:36 AM
many thanks for the reply, i know that both the consumables are the same (i.e.drum and developer) as each other but my problem is will the grooves on the bottles line up to fit into the housing in the toner bank. sorry for not making this clear. oce part number for toner ?
DadO
12-04-2008, 05:07 PM
Its on u to try :). If bottle isn't fitting then toner surely will : ) but dont take me for granted since i didn't saw oce version of bizhub pro C6500
ni311
12-04-2008, 07:02 PM
If the developer is the same, from my logic, the toner should have the same exactly the same properties. Try to modify the toner bottle or the toner hopper mechanism. In the worst case scenario, just put the toner from one bottle to another.
I know you want the answer if it's fitting or not but this is all I can help you, sorry :)
Specilist KVN
12-05-2008, 06:19 PM
If the bottle will not fit do NOT force/modify it it.
Depending on the Machine KM does upgrade their tomer with model upgrades.
The 6501 uses new toner.
Seeing as the toner is such an IMPORTANT component of the machine i would not mess with it. You may not get the desired results.
ni311
12-06-2008, 09:49 AM
KVN, if the C6501 is using new toner, how come it is using the same developer as 6500?!
kmcopier
12-07-2008, 11:50 AM
Toner (OEM)is the same and it fits but trie to get it out CMY (K no problem) you have to cut in the hopper unit a small rib take a torch and you see it
Setright
12-22-2008, 08:48 AM
I work for OcÚ and will dispense my experience here:
6500 / CS650 toner is the same, but "our" bottles are different.
6501 / CS665 (?) bottles fit, but the end cap is different. We have used KoMi toner in CS665 by simply transplanting the end caps. Don't pour the toner over.
This may also be the case with 6500/650, but I haven't tried it. No worries on the chemical make-up.
random
12-22-2008, 09:43 AM
They have only increased the capacity of the toner cartridge.
CS665
03-06-2009, 03:17 AM
Does anyone know the keypad sequence to get into service mode on the Oce cs665 or KM C6501
Setright
03-06-2009, 09:40 AM
Well, yes.
Not to be a party-pooper, but I don't know that we should share such information here. Could get into the "wrong" hands.
CS665
03-06-2009, 11:17 PM
Thanks anyway
Found my cheat sheet
FYI
Utility
stop
0
0
stop
0
1
Setright
03-07-2009, 07:20 AM
Admin , maybe this isn't such a smart thing to have posted ?
ni311
03-07-2009, 08:49 PM
I'm getting scared, you're servicing a C6500 and you don't know how to enter in the service mode.
I am wondering what you'll do in the service mode since you didn't know even how to enter in this mode...
Vaprinter
05-19-2011, 07:03 PM
650 Toner bottles don't align in 665 toner housing slots. Clipped off tabs on front of toner bottle from cs650 and ran in cs665 no problem.
