View Full Version : Konica di 550 c0f24
What do You think about that problem? I've tried to find AIDC Sensor (i should clean it), but i've got problem with finding it :( ... Trouble reset doesn't help...
http://img155.imageshack.us/img155/7488/sensorsw4.th.jpg (http://img155.imageshack.us/my.php?image=sensorsw4.jpg)
can You help me? give some tips...
greetings
copytechman
12-03-2008, 05:44 PM
The aidc sensor is usually right under the middle of cleaning unit below the anti-spill/recovery mylar.. It least thats where it is on the old minolta's i've serviced b4!
Regards
A.
brent
12-03-2008, 07:37 PM
this is a common problem. when the machine has not been serviced in a while the toner will spill onto the aidc sensor. almost guranteed you find this out. take the drum unit. remove drum and you will most likely find a toner spill onto that aidc sensor. not the atdc sensor in the dv unit. give it a try
brent
cobiray
12-04-2008, 02:35 AM
With the age of the machine, it's likely the anti spill mylar on the cleaning section is fatigued and in need of replacement. Been there, done that, bought the t shirt.
thanks a lot for Your tips...
i'll try to do this... then i will say how it goes :)
thanks a lot :)
Edit: Guys! I (We ;) ) did it!!!!
It was the sensor (i cleaned it)...
thanks a lot for Your response... You help me a lot :) !
greetings from Poland :)
cobiray: what does it mean? "Been there, done that, bought the t shirt." is it a proverb? :)
cobiray
12-04-2008, 05:50 PM
No, it just means I've seen it before on several occasions.
